the old girl,,finally started to act up..339,480!!!!!! changed the lift pump,,cleaned the filter bowl,,and changed filter...fire up,head down the road,,could be 5 minutes later,1 minute,,changes..check engine light comes on,,and starts to stall out,,then catches. may run ok for a changing period of time,then does same thing. never kills tho. hooked up my snap on scanner,,NO CODES!!! neighbor next door is full time tech on all brands,,thought maybe scanner was lying..NOPE,,he couldnt get any codes either.ran down the road with scanner hooked up--NO CODES!!! starting to fire me up.. any thoughts,anyone?????????
