I was reading the other post, and it got me thinking of my truck. I have a similar problem. At idle the engine seems like it is missing, and there is a definite knock. However, it doesn't sound like a bearing knock as it's frequency is too slow. As I am cruising do the highway, the engine runs fine. I have also recently replace all the injectors because I didn't know the condition of the ones that came with the truck when I bought it, and I was told by someone else that the noise could be an injector knock. However, the noise was still there. I've even tried loosening the injectors to try and pin point which cylinder is making the noise, but no such luck.
So I did a compression test anyway. Here are the results:
1=425
2=460
3=460
4=410
5=460
6=420
7=370
8=460
So it looks like #7 is the one that is giving me the issue at idle. I would assume that all the other cylinders have good readings? Since #4 and #6 were the lowest, and they are right next to each other, should I be concerned about a head gasket or even head issue? I'm not loosing any coolant. What would cause #7 to be so much lower than the others? Any I looking at a complete engine rebuild, or do you guys think just doing a head/valve job would make my numbers more even across the board?
Thanks for your advice.
Tim
1=425
2=460
3=460
4=410
5=460
6=420
7=370
8=460
Tim
