DYED FUEL?
VanBoy
WA
You shouldn't be discussing this....they could be listening....
LOL
Let them dip my tanks. I run semi on the road and for the amount of fuel I burn per year, it's not worth it if caught. I tend to get pulled over for a weight check at least once during harvest (and the usual once over). But I know what they look for..... first and for most, don't give them reason to pull you over (ie keep your lights working, keep your tires filled so they don't buldge).
kerrynzl
New Zealand
Down here in NZ the govt used to dye "farm rebate gasoline" years ago,
My dad used to filter the stuff through bleaching clay to remove the dye.
The clay is sometimes known as "fullers earth" or "bensonite clay"
I don't know if this will work with diesel or not [ mybe you can try ]
