dual wheel
jocephus
campbell/mo
i am wanting to convert my single wheel truck to duals how is the best way to do it are the axels the same in the back or are the dual wheel trucks wider and are the spring peches the same on both if they are wider also on the front is it the same with a different hub or a totally different axle. any info would greatly be appreciated you guys have helped me a hole lot thanks.
Double-S-Diesel
parts seller
derry pa
on the front the adapters just bolt to the existing studs.
as for the rear, a dually pickup, NOT a cab and chassis rear is the same width at the spring perches, the caliper, brake pads, hoses, etc are all the same, only differnce is the u joint
u2slow
bilge rat
Coastal BC
Are you just trying to up the weight carrying ability, or you want the look?
19.5" tires and wheels can get you up to nearly 5000# per corner.
jocephus
campbell/mo
i pull a 25ft gooseneck flatbed and it has tandem duals i i like the look first off and with duals i could use the truck spare for a trailer spare. and i like the stability the duals offer and i am planning to put a flat bed on this truck.
