Mont91
If you do a flow test on a glass pack versus a straight pipe you will see that the glass pack causes a fair amount of back pressure because of the turbulence it creates, and if you were to cut that cherry bomb open there most likely would not be any packing left. Is a glass pack better than some mufflers? Yes. Is it better than a good muffler? No. Any muffler that has a zero back pressure rating would be better than a pack or the stock muffler, then the choice is do you want noise or not. I currently have a 3" with pack, the pack came with the used 3", and unless you are accelerating at high rpm, you can not hear it.
