DT360 into 1991 F350
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Just a teaser. My IDI runs so well I don't have the heart to pull it yet. Just acquired 2 DTA360 engines, a 1991 185HP and 1992 190HP. The plan is to get the adaptor plate to bolt it to my ZF5 and just tweak the pump a little.
Picking them up:
Also grabbed a 1956 IH S-120, towed the whole load 10 hours back to PA with the ol' IDI. did flawless towing about 18K lbs.
Unloaded
Both fired right up with NO effort!
http://youtu.be/km-fjezZtWs?list=UUjBIAxHF142z1WcqZHEOhZw
http://youtu.be/mVUQGBJfHXk?list=UUjBIAxHF142z1WcqZHEOhZw
ZWilson07
Cowboy
West Point, Kentucky
Drool!
You must have got a great deal on everything to make that drive and I am super jealous they fired up that easy. Will definitely be following this. ;Sweet
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Suppose I'll update this now. Started the tear down!
Got a gooseneck setup to use my trailer and hauled 6 scouts for a friend. Last good tow and truck did amazing. Even with the idi.
Drained the transmission and t case, both spotless inside.
Scored a brand new NAPA starter for doing some work on a friends truck.
Didn't want to split the trans open but this gouge in the "quill" as Ford calls it needed to be fixed. Unfortunately it was impossible to repair add it's only sheetmetal. I was able to source one directly through ZF.
Wasn't so bad, close inspection shows it must have been rebuilt. The bearings are spotless and the syncros show no wear at all.
Corrosion cracked the tail housing. Luckily my friend had an aluminum welder I could use and I fixed it.
Scary having this out.....
New parts and seals.
Back together and ready to paint.
Clutch and flywheel kit.
Adaptor plate is on its way.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Figured to eliminate the spring wrap and take out the blocks I'll rebuild the spring packs and install a SKY shackle flip and "6 inch lift". Only lifted my truck 1-3/4 as I was using it to remove the blocks I had, which in turn picked it up just right with the RSK. Was perfectly level before.
Annnnnnddddd teardown begins. I have 98% of the parts to start the swap. T case and engine gasket sets are on their way.
This July 4th weekend I have 4 days off. Should be able to slam out some work. Goal is to tow 2 vehicles to Carlisle all truck nationals DT powered.
BrandonMag
Dana 50 rebuilder
Oregon east
How was the process of pulling the gears out of the ZF? IIRC, a transmission rebuilder once told me you have to heat the case to split it because the tolerances are so tight.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Kept plugging away. Ready for a little cleanup and some test fitting!
04_6.0
Lake charles
Awesome!!!! Keep at it and take lots and lots of pictures. You will never know when you need to look at something at a later date. I did my cummins swap in a three day weekend. It was tough but I got it done.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
lots to cut out....was a pain in the ass.
Empty engine bay.
Test fit it. Won't have a good idea till I get the transmission behind it. Should be getting the adaptor Friday.
Roomy...
Modified front horseshoe
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Modified the factory bracket to fit a 3g alternator
Some wiring cleanup. Lots of extra junk with the E4ohno that lived in the truck.
And finally the dual battery tray I'm mounting on the passenger side frame rail under the bed.
I like the dual battery tray idea. I've contemplated doing that to mine but just on the pass side under hood. Will it give you enough room to run Group 31's? Being that it's a brick nose truck, I'd be tempted to just toss the wiring and start over. So what are you going to do about a fan? Your definition of roomy and mine are pretty different. :D
Will the engine/mounts take place of the crossmember, like in a bigger truck? Or are you going to replace the crossmember around the engine?
dieselmainiac
