DT 360 / 466 flywheel interchange?
johndear720
Does anyone know if a DT 360 manual flywheel will work on a DT 466? I assume if there are no balance "bulges" and the bolt pattern is the same then it is OK.
In the process of swapping a 360 to a 466 and discovered the intake on the 360 points down and on the 466 points up. My aftercooler plumbing is for the "down" intake. Is there a different pipe for the 466 to go up top or is there an upside down intake?
Thanks,
ntjapkes
