Certainly could be an indication that your static timing is a little too advanced though if it really is "overly" loud.
Takes just a second to unplug the advance wire ontop of the IP, can't say if it is the front or back one, but mine has little tags on the wires. You might try it and see if you like it better.
You'll know if you got the wrong one cause it just won't start at all.
The fuel solenoid connection is the wire closest to the front of the truck on top of the IP, one wire is longer than the other that goes to the cold advance.
Lots of information and mis-information has been discussed about the Hi idle and Cold advance solenoid on the IP.
Both of these are controlled (turned ON and OFF) by the Engine heat sensor located on the passengers side close to #1 glow plug. It is a normally closed switch when cold and opens when the coolant temp raises to 120* on that head.
That side head is the controlling factor on how fast the coolant heat rises. With the WRONG t'stat (Only a Motorcraft or an IH t'stat is correct) the coolant will NOT be closed off preventing flow to the Radiator, a small amount of coolant will flow thru the bypass to the water pump then back thru the block until the t'stat opens for the coolant to flow thru the radiator. If the cab heater is on there will be circulation from the water pump thru the cab heater back to the block. In the heater hose is a tee with a hose going to the bottom of the radiator connected to an orfice fitting, this helps to warm the tranny fluid quicker. There is also an orfice with a ball check valve in the T'stat neck which allows a small amount of flow to the radiator, also for bleeding any air in the block, this closes when the t'stat opens allowing flow to the radiator.
I've read where this ball has been removed, and sometimes the hole blocked off, it's there for a reason. then they wonder why they have coolant heat or not enough heat problems.
Motorcraft t'stat---start to open @ 180* fully open at 195*
The t'stat shown is the correct configuration, it was in one of my trucks, but was mutilated, evidently they had cooling problems, but did the wrong things. More pix in my webshots.
