Drivetrain parts several of them
76ford466
Another member
Honaker, Va
For sale Dana 44 high pinion 3.55 gear set Dana brand $45 ford 10.25 short yoke 3.55 gear set original ford $50 Chevy 10 bolt 8.625 3.42 gear set less than 35,000 miles excellent shape $50 Dana 44 lower numerical ratio open carrier fits up to 4.10 excluding 4.10 $35 Chevy 10 bolt front open ratio carrier unknown low or high ratio casting $20 9 inch ford stock center housing bare $50 ford T18 Borg Warner 4 speed for 2wd or divorced t case cleaned painted and new rear seal less than 100,000 on it shifted good $300. Chevy 350 engine to turbo 400 trans custom built Convertor ran one time 3,000 stall 10" over 600 new sell for $300. Ford 9 inch 3.00 gear set and 28 spline open diff $60 or separate. Stock 1310 front yoke from 205 t case stock rear yoke 1330 from 205. Ford c6 2wd trans with Convertor long tail shaft $150. C6 minus Convertor a different one long tailshaft $125. Prices are without shipping would rather not ship the transmission prefer pickup. Would like to get some of this stuff out of garage to help with required parts for another year of truck pulling Can call 276 701 5939 located in Honaker, va
Mulochico
Modesto, Ca
It would help your cause and get the info out there better if you put each item on a separate line
For sale
Ford 10.25 short yoke 3.55 gear set original ford $50
Ford T18 Borg Warner 4 speed for 2wd or divorced t case cleaned painted and new rear seal less than 100,000 on it shifted good $300.
Prices are without shipping would rather not ship the transmission prefer pickup. Would like to get some of this stuff out of garage to help with required parts for another year of truck pulling, Can call 276 701 5939 located in Honaker, va
I'm bored.
Sent from my USCC-C6721 using Tapatalk
76ford466
Another member
Honaker, Va
Hey thanks, I ment to type it upp nice but I was in a hurry when i posted it. The C6 trans are for a 460. Also have a set of 460 d3ve-a2a heads for sale, all stock. A rebuild woulnt hurt but they was on a running engine. $150. And a custom cam for a 460 a hot street cam by Cam research .588ish lift 236/248 duration at 0.050 pm for complete specs. Ran great on my 11:1 pump gas motor. Also have for sale my 460 Jasper reman engine crrently in my 92 F350 very fresh i was told 3,000 miles. Can call jasper to verify. Sell it and the e4od with a new converter shifts very good. Complete i mean everything. For$2000 engine was $3200 for it alone.
Seven4eight
