Driveshaft
frankenwrench
overkill is under rated!
Weatherford tx
I have a 91 with a 7.3 zf5 4x4 cab and a half but need the rear and front drive shafts. Anyone in tx selling them?
cre1992
Florida
Do you have a F-350 or F250 ? Transfer cases will be the same model, but the transfer case on the 350 has a yoke the front driveshaft will have a cardan joint.
I have a F-250 front driveshaft here in florida. When I ZF5 swapped my F350 I bought a new front driveshaft instead of shortening the F350/E4OD front driveshaft as well.
This is the one I used my truck.
frankenwrench
Weatherford tx
I have fixed yolks all the way around with straps. Front diff and rear. Same with my transfer case. Fixed yolks with straps.
radeon1314
