Logroller
Well all just had to replace my driveshaft today , couldnt figure out where the vibration was coming from ,, so i took the beast to the local joint and clutch shop ,, come to find out the drive shaft was 2 inches too short ... And from what the shop told me this is a common thing on all 93 f-350 diesels ,, so just a word of wisdom to anyone owning a f-350 measure out of your tail shaft and if you have more than 2inches showing on your slip yoke and you have alot of vibrations from 65mph and up then you might have the same problem i had ... so just do some checking it might not be your u-joints or tranny .... just food for thought ....
