Drive shaft for single cab with 6.9, C6, & Sterling axle
Biofuels4Change
Sarasota, FL
Hello! I have an 86 F250 with the 6.9 engine, C6, transmission, and Sterling rear axle. The folks on Ebay say that a shaft from any 133" wheel base model will work. Any one have knowledge of this? Otherwise, I am looking for a stock shaft so I can remove the DNE2 and give it a look over.
Va_Mike
Southeastern Virginia
I have a drive shaft out of a 89 F250 with a 7.3 that had a C6 and the sterling rear end. I was keeping it to potentially make a straight driveshaft for my extended cab. But I will probably never get around to that.
typ4
Newberg,OR
Sucks you are in florida, im parting an 87.
REM70
