Matt_INW
I just drained and removed the radiator to have the top tank resealed. It's been in 15 months since it was installed new, and the entire cooling system, and the coolant was new then too. I don't recall what the old 25 year old radiator looked like inside, some buildup as I recall but not alot.
Should I be concerned with what I see? Sorry I should have taken the pictures in the daylight instead of just now with a flash. The coolant looked fine, nothing abnormal at all. But the inside of the radiator seems to have a thin white/gray film. No symptoms of problems, the last oil change it went 2,500 or so miles without needing oil, was down 1 to 1.5 quart (so still above add). The coolant temps did get up to 233 two times a couple weeks ago, now I have a working fan clutch. I did give it a little oil right before that trip, it was down about a quart, which often it stays near but I gave it a little more since I was hauling 10k. I haven't checked the oil since the trip.
I DO recall accidentally putting in a cup or two of windshield washer fluid in the overfill tank a few months ago instead of the windshield washer tank, oops.
Anywho am I worried about nothing or....? I'll ask the radiator guy tomorrow if he has any thoughts. I know these photos aren't great. I'll try to take some in the daylight in the AM, if I remember, before I drop it off to have the top tank resealed.
Thank you,
Thank you,
