Downpipe?
Preems14
Redcliff, Alberta, Canada
I want to upgrade my exhaust mainly for the downpipe. Does anyone sell the downpipe for the factory turbo, or do i have to buy a whole exhaust kit?
FordGuy100
Silverton, OR
I heard that banks did, but I dont know if they still do. If not, the ATS upgrade kit is your only option unless you go custom.
Diesel JD
Gainesville, FL
I kind of think it doesn't but Mel would be the guy to ask about hypermax stuff. 4x4truckingirl, classicfordguy and probably others have done something like weld a piece of 3" pipe to the factory flange and then bolt on an appropriately bent pipe or appropriately sized flexpipe. Lots cheaper and easier than the ATS kit. I think the hypermax downpipe is good but really different from the ATS/Ford stuff, but I'm not totally sure.
Preems14
I would make something myself but i would have troubles accessing a welder and ive only welded a few times in shop class at school and i wouldnt want to weld something then put it on my truck i wouldnt trust it.
forcefed
Newark, OH
I have the ats upgraded housing and downpipe but never installed yet due to the housing. The outlet of the housing is too small to fit a 3" inside of it. Tried all of the tricks of freezing and heating but no luck. So I would stay away from ats if I was you. just my .02 though.
hesutton
The Anti-Anderson
Bowling Green, KY
Would there be any way to make room for a 4" setup if you went custom?
Maybe........You would likely need a body lift of about 3 inches and a big sledge to make a down pipe shaped dent down your firewall. 4 inch would be really tight between the engine/tanny and the firewall.:dunno
Heath
typ4
Newberg,OR
Just get a 3 inch bent at a shop and cut your flange off and have them weld it on after you get it fitted and marked, the stock pipe is really restricted, and I will say it again, yes the housing upgrade is nice but we did one at work as I described and it made one hell of a difference. And if the new housings are junk, then what is the point of fighting with a business that doesnt want to support older trucks anyway.
I am cranky today.:backoff
4x4TruckinGirl
"Cowgirl"
Dixon, MO
ATS makes a factory downpipe for this truck, cost is about 150$ and last I checked it was on backorder for who knows how long according to the extremely helpful rep............
now, what I ended up doing....... took 2.5" exhaust pipe, cut off the factory flange and cut n welded the pipe till it seated up their properly..... my cost...... F R E E........ (time + welding) It was supposed to be 3" DP but that required beating of the firewall, which is fine, but for ease ended up doing the 2.5".....
