93turbo_animal
I know there is another thread about this but thought I would start one for fixes. I have fixed 2 of these now 2 different ways. The first one I tried to fix the cause of the problem which I beleive is the pivots wear out causing 2 much slop to pull the cable all the way. I ended up getting tired of messing with it and bought a new unit from ford which is a permanent fix or atleast as good as it was new but that was expensive. The second one I left the slop alone and simply tightened the cable like you would on a motorcycle. You can see in the pics where the cable mounts and how I opened it up then I welded the gap so it wouldn't pull shut and it works great now. This was quick and easy and should last a long time also but that is yet to be seen
