Ididriver
so itll work if i use it as a down pipe conecting to a 4in exhaust with no problems? sweett!
thank you sir.
thank you sir.
thank you sir.
Congrats Darrin, looks good. What's the HP and tqu. numbers on a 4bt?
Awesome job getting it done, thanks for the pics allong the way. It let me live vicariously through you guys.
Thanks Gary.
I used a 4BTA that is rated at 120HP Stock, and I think 320 Torque. With the mods that I did (Prince of Darkness Injectors, Turbo off a 5.9 6Bt, Denny Fuel Pin, 3200 Gov Spring, pump adjustments, exhaust and intake) I should be over 200 HP and 450 on the torque.
It pulls harder than the 5.0 Gasser!
Thanks, Glad you like the pics and the build.
UPDATE! The truck started right up made it to Church, this morning, Quodabas for lunch and back home.
I need to stop by and check that thing out one day when I am up un Michigan. All my family is from owosso and we run around over there all the time.
. More than a lot of the IDI's on this forum! Very Sweet Darrin. I can't wait to see video footage of this thing pushing big piles of white stuff around your lot.
darrin what are the part numbers for those napa gauges they look sweet i really like them
any vibration transfer issues? The 70s ford crew with a 4bt that I have been around buzzes the whole cab. Runs real good though and 25mpg in a one ton 4x4 crew.
AHHHH!!!!!
What did you do to the front fender??????
Still waiting on videos darrin
