Fordsandguns
Fords Rule
I just replaced the soft hoses on the front brakes and while I was there I noticed that the pads on the drivers side were worn much thinner than the pass side.
The rotor also looked like it had been getting hot. I was thinking that this was caused by the hose breaking down inside and holing pressure on it.
But it still seems like it is holding pressure on the rotor even now.
With the wheel off I can rotate the rotor by hand but it will only free spool about a quarter turn when released.
So is this too tight? Do I need another caliper?
