These turbo shafts rides on a film of oil. If the engine is NOT running (no oil pressure) You will not be able to get a real picture of the condition of the 'bearings'.
If you spin the shaft by hand, there should be a very slight resistance. (remember, there's no oil on the bearing) There should be a little end play. But the rotors should not hit either shroud.
That's what I kept telling myself - no oil = no spin. But I really had no idea.
I wouldn't condemn the turbo yet. Go back and re-check Your work. I'd almost bet that You have a boost, and/or exhaust leak.
Did You take the IP off, to tweak the fuel? Did You even adjust the fuel screw?[/QUOT
Yes, I bought a turboed parts truck and I switched pumps as well. I have not adjusted it at all.
I have the factory Garrett turbo on my 94 and even with the engine off no oil being pumped into the bearings i can free spin it for about 2 minutes just by flicking it with a finger. I dont know if this is just a fluke with mine or what but maybe its something to compare to?
