Detroit 6V-53 swap questions
Daniel McCurdy
Evarts KY
Has anybody swaped a 6v53 into an obs ford was interested to see what kind of room there's is. I figured the 6v53 should be a smidge shorter than the 4-53 as it's 3 cyl in a row vs 4 but not for sure on that. My main interest would be to see if there's enough room for a mechanical fan.
Daniel McCurdy
Evarts KY
Was also wondering how twin turbos compare to compound turbos. I imagine twin turbos would be a lot easier to make fit.
Mt_Man
Portland, Oregon
Cool idea. I saw a guy swap in a 4-53 into mid 2000s ford on youtube. It was pretty slick. He got the automatic transmission to work with it too. It would be cool to see if it fits.
Daniel McCurdy
Evarts KY
Yea the 6v53 came factory with 400hp in marine applications so I imagine 450-500hp should be possible with good reliability. I seen one guy who did some work on a 4-53 and got around 350hp but the torque was insane over 900 lbs.
lotzagoodstuff
Carmel, IN
You might be able to make it fit, but I think the weight of that engine will be the hold up.
Daniel McCurdy
Evarts KY
The full aluminum engine only ways about 1150-1200 about the same or within a 100 lbs of the Cummins so I think weight won't be a problem
lotzagoodstuff
Carmel, IN
Good call. I didn't think about the aluminum version. That really does make a big weight difference.
TNBrett
Middle Tennessee
When I bought my 92 F350 with a bad motor, I already had a 6v53T sitting in my shop. I really wanted to find a way to make it work, but my tape measure convinced me otherwise. Height was the biggest problem. Mine was a single turbo and basically it was going to be about 10” higher than the hood. The 6v53 is a BIG motor.
I ended up selling the Detroit and the truck got a 93 7.3 IDIT.
NeverHave-I-Ether
Texas
I found some Detroit's south of Austin. Several V6s and Inline 4s. They are block cores and either N/A or the turbo is missing. I get more pictures Monday. If they are 53 series I'll pick them up for rebuild. I think I can get 3 cores for $500.
Never-Have-I-Ether
720Diesel
