Decided to rebuild the IDI
IDIn_It
Pensacola FL
So i came to a conclusion that i should go ahead and rebuild the IDI. it has coolant loss, oil leaks, etc. I got the truck running again and drove it maybe 30 miles total every since i had it maybe 5 months now. It ran strong but problems started showing up. Where can i find the gasket kits for the turbo engine? I searched on google (im a search freak) and cannot find anything. Every link that i find says Non turbo. I did find one though called falcon global on ebay for gaskets and other parts. Is this the go to company for IDI rebuild parts? What should i be on the look out for when taking apart/ rebuilding the motor? Cavitation should be the first thing i suppose. i would really like to make this $1000 dually a long trip hauler without any problems. Truck is young with only 183,***. Thanks.
cpdenton
Truck needs paint.
Conway AR
Gasket set should be the same for all idi engines now. Once the newer turbo spec'd engines came out, all the gasket sets were updated to those specs.
A rebuild with good parts won't be cheap, but it will be cheaper than buying a new 65000 dollar truck!
honestly, the cheapest, best thing to do is just buy a promar engine.
3500 ish dollars to your door and DONE!
they sleeve all their blocks, so cavitation is a thing of the past as long as you sca your coolant.
you can go through all the motions of rebuilding it, but its still gonna run you about 3 grand, and its going to take alot longer.
http://www.ebay.com/itm/Reman-93-94...ine-/371297895421?hash=item56731443fd&vxp=mtr
this will come to you as a long block. you can add features like head studs for an extra price.
everything else can be had at your local auto stores or favorite website.
if you want this rig to not be a custom build and you wanna just drive it, this is my opinion.
i have 100k on my stock 94 7.3 in my 87 F350 CC+ SSB
a 105 cc IP, mister injectors, clapped out ATS 093, and a ZF5. shes no slouch.
and youll have a 3 ry/75000 mi warranty
FORDF250HDXLT
Maine & Oklahoma
1988
Engine
Ford Truck F450 Super Duty . 15C047 $900 Bradford Auto Parts & Salvage, Inc. USA-FL(Starke) Request_Quote 1-904-966-0774/1-866-836-1264 Request_Insurance_Quote
^he's got 4 of them to pick from for this price.
IDIn_It
Pensacola FL
Alrighty then, wanted to make sure. so the only thing that would be different from the Turbo and the N/A is the wrist pins on the pistons? a $65,000 truck would be nice but i love my OBS lol.
IDIn_It
Pensacola FL
I will consider going that route if i have no major issues. I plan on making it a long trip hauler with a few performance mods such as getting rid of that stupid crushed down pipe and upgrading to the 3 in and upgraded pump. Do u know if that wicked wheel will fit the factory garret turbo instead of the ATS?
stealth13777
Jacksonville, FL
IDIoit is right about the promar. I spent about that much on my rebuild when you include machine work, and I didn't do new pistons or sleeve the motor. I enjoyed building mine though. Your call on what you want to do.
As I understand, your flywheel and harmonic balancer are different being a turbo motor, but if I'm wrong someone here will correct me. Plus what you already mentioned.
jim_22
Cape Cod, MA
The fine print says the warranty is void if the vehicle is over 1 ton!
"3 Year 75,000 miles Warranty accept for Ambulance, Off Highway Use, Package Delivery, Police, Taxi, Limousine, Tow Truck or any vehicle over one (1) ton."
sassyrel
iowa
coating on top of pistons, harder forging in them for turbo. 33 m/m vs 30 m/m wrist pins, icononickel for valves, and hardened seats. if has the original oil cooler,,higher fin count for additional heat...SUPPOSEDLY higher nickel block casting
I do have a new set of .020 pistons with rings, ford oem. If needed.
i will be building my own one day.
but alot of other projects on the list first.
and since it will either go into a 1 ton or a 2.5 ton, i guess the fact of the warranty is out of the window.
perfect for the F250 guys??
its still not a bad price for a sleeved, reman'd engine.
the fact that they sleeve all of their engines is what got me on this hype.
Any 7.3 idi gasket set will work. Just make sure you have a 7.3 and not a 6.9 engine. Now how are you certain you have a factory turbo engine in this truck? Any idi engine will fit in the same place the factory turbo engine fits. All the idi engines are drilled the same. Now knowing all this you still can't be sure the possible turbo engine actually has the internal turbo rods and pistons. Only by opening this engine can you tell what you have. Now for a gasket set. Felpro has proven to be about the best there is. Many here really lke the Victor Reinz gaskets too. Now for the oil pan gasket. DO NOT USE ONE... This is important. The factory used an RTV and it really works. Some have tried the gaskets found in some kits only to end up pulling the engines again because they leaked. Its nearly impossible to remove the oil pan in the truck because of the oil pump pick up tube. Its all the way down deep in the sump about 1/8 inch above the oil drain plug. Don't believe that. Next time you change oil stick a rod or screwdriver up in th hole. Promar is a really great company to buy from. They stand behind what they sell. Another good company is Barnett Performance. Finally Mel at Conestoga Diesel Injection is also selling complete turbo engines.
IDIn_It
Pensacola FL
Mine is a turbo charged 94 7.3l XLT IDI Vin k. It didn't come with the factory ATS package.
FORDF250HDXLT
Maine & Oklahoma
unless the 8th digit in the vin is an M then it came with the optional factory turbo engine.though it might not say "ATS" on it anywhere.that's who ford had build the turbo kits for them back in '93 and '94.
JU57US
