Dash wiring
Jack Barber
Sweet Home,OR
Would a gas truck dash wiring harness work in my 1988 7.3 mins the glow plug water in fuel wiring ? I can add those to the harness Would the tach wiring be the same? Thanks
At the tach, the wiring may be the same, but it is different at the engine pick up points. I'm not sure how far from the tach the wiring the two would be the same. The easy answer would be to use another wiring harness from a diesel.
Scotty4
I tried using the one I got from a 460 and after some research found the mag pickup used on the IP does not pair with the gasser. The tach housing looks different too. But mine is an 85 so I dont know how a brick is set up.
