Dash Lights out need some Help!
pwjackson
Saint Paris/OH
Okay my dash lights are out but just the ones the light up the speedometer and fuel guages and such. My turn signal indicator lights both work and my high beam light works. I justed checked the bulbs and they light up. I recently replaced the headlight dimmer switch also. What else would cause these few light to not come on? The headlight on and off switch??
87crewdually
Southern Nj.
The headlight on/off switch certainly does turn them on. The dimmer switch on the floor is irrelevent. I'd check the connection first before buying a new one.
Sycostang67
Scooty Puff Junior
Kuna, ID
x2 on the fuses, chances are your exterior marker lights aren't working either as they are on the same fuse.
fury9
island lake il
make sure for some reason or other your circuit board on the back of the dash cluster isn't corroded or worn through. The actual bulb holding units may be at fault. But it is probably a stupid wire or something. Also you should hook up the headlight relay mod , you may have already burned up your switch.
