Cut crew cab in half to add ambulance box with pass through
Jbone36
California
*Edit.. Nevermind i was just thinking.. putting box on the f250 is a no go..92 f350 dually box would be too wide for the truck. Guess im going to pull the engine and trans from 99 and pop it in the ambo.. it had a 94 powerstroke serpentine in it before so should be good to go.. anyone think of why this wouldn't work?
Jbone36
California
So i guess now im asking if yall think the 99 engine and trans will go in the ambulance..both are 4x4 thanks
Jbone36
California
Thanks all
93didually
Michigan
You would have to fit the 99 wiring into the obs to make it work, the 99 trans uses two extra sensors that 97 down don't have. Otherwise go single shot injectors and your trans with the 95-97 wire harness and ecm
Seven4eight
