justblowin'smoke
I'm just wondering if anyone has done this perferably in a 84-87 chevy pickup and if anyone knows where to get motor mounts and adapters
That has got to be one of the silliest ideas ever. ;pjustblowin'smoke said:I'm just wondering if anyone has done this perferably in a 84-87 chevy pickup and if anyone knows where to get motor mounts and adapters
smartass.rubberfish said:That has got to be one of the silliest ideas ever. ;p
Who,,,,,me?????towcat said:smartass.
Gee...you're so nice.......rubberfish said:Who,,,,,me?????
Seriously though, I don't see why it wouldn't work.
As far as I know there isn't a "kit" that one picks up from a parts store.
I think everything would have to be fabbed up. 24vchevy will find this
thread soon enough and be able to shead some more light on that.
Here Towcat, I got you a little something for Christmas.
I did a 91 Dually Crewcab which is the same frame and body and it is a 4x4 as well. I used the original Cummins motor mounts out of the dodge and cut them veerticaly then lowered the engine down and re-welded the mounts. I also had to adjust the angle just slightly to get them to sit on the original chevy mtr mnt towers that i slotted like a ford or dodge mount then came the fun part ... building the new mtr mnt crossmember to clear the oil pan and the front diff .. as well as the tie rods ... I was able to set the engine all the way down into the frame by modifying the front cross member by removing the top flange and re-welding it on backwards and facing forward instead of back ... iI had to bend my brake lines some to clear the A/C compressor and lower the brake proportioning valve ... if I was to do it over I would relocate the valve and lines completely as my A/C pully does make slight contact with my brake lines on hard downshift applications with a trailer ... I also put a 4" charge air cooler into the rad support by removing the vertical support braces and puttiong the dodge red mounts into the chevy rad support. It looks like a factory job .. Almost .. i never got around to painting any of the modifications .. I will be taking the truck apart in the next month or so to lupgrade the 93 cummins to a 98 with very low miles and i plan on taking lots of pics this time ... If you have any more questions just let me know
