Cummins in 94 f250 possibilities?
Turboed94
Central florida
I have a 94 f250 with the IDI in it I'm starting to consider a 12v swap i want to be able to make pretty decen power (350hp) and to have something diffrent lol but I just want some details/tips from some of y'all that bag already done it, just some general details
Price range?
Adapters,mounts?
Wiring
Using the zf tranny
Fittin the engine(fire wall trimming? And intercoller)
fellro86
Iowa County, Iowa
I used the Dodge trans mainly to avoid the price of the adapter plates. It gave me a lot of freedom as well in locating the motor, which does not have to require firewall modification. I did fold the lip over to get it out of the way, but nothing more. I also covered the firewall in heat resistant insulation. It depends which Cummins you are going to use, but the VE and P-pump versions are the easiest to wire. Only one is needed to make it run, then you have plenty of options again on the alternator. I chose to re-use the Dodge radiator from a 1st gen for mine, as is simplified both intercooler and radiator hose troubles.
