Going through the SPEED CONTROL INOPERATIVE TEST
A1 VISUAL CHECK yes the cable is connected from the ip to the servo and working properly
A2 SETUP yea I did this too not with a rotunda though
A3 "VERIFY THER IS POWER TO SERVO" I get 12.75V PASS
A4 "CHECK FOR STUCK BRAKE SWITCH" I get 0.0 PASS
A5 "CHECK BRAKE/CLUTCH CIRCUIT" I get 0 PASS
A6 "CHCK DEACTIVATOR CIRCUIT" I get 12.6 PASS
Everything checks out up to A7 "CHECK FOR STUCK ON SWITCH" I dont get 0 volts or 12V it bounces around in mV. So i am guessing something is going on with the ON switch.
I proceeded
A8 "CHECK ON SWITCH OPERATION" I get 12.3V PASS
A9 "CHECK FOR STUCK COMMAND SWITCH" I get 0.0L FAIL
A10 "CHECK SET/ACCEL SWITCH OPER" I get 678 PASS
A11 "VERIFY SPEED SIGNAL" I get 4.77 PASS
So looks to me like I have a bad ON switch, FORD wants $135, XL Parts has them for $70, Pick a part on the North side of Houston has them for $8.
Guess where I'm going.
Actually if I new 100% this would fix it I might spend the $70.
Wish I could find someone who had one close that I could try to be sure it was right. But everyone has to order it.
My other situation may be related, when I am running at a steady speed with constant pressure on the go pedal if I lightly press on the brake and hold it, my RPMs jump about 300 rpms and then surge.
What could this possibly be??? the BOO switch??
I proceeded
