Changed out my vac pump today. Pressed the pulley on with a bolt and spacer. Looking at the inner edge of the pulley to the shaft, everything looks even. When its running on the truck tho, it quickly "walks" back and forth. The shaft on the pump isn't bent, I eyeballed it before I started. Does it sound like I just have the pulley a bit off, or can the pulley actually be bent by pulling it off? I did use the correct puller. Also will it hurt much to run it? It's not a bad walk and it doesn't affect the belt in any way.
