It will bolt directly toany 6.9 or 7.3 engine. Both of these engines were drilled the same. Demensionally they are the same exact engine for bolting any parts from a 6.9 to a 7.3. Also almost all the internal parts share the same parts. The only differance in the 6.9 and 7.3 na engine is the piston size. Everything else will cross back and forth between these engines... Kinda a good thing being able to "find" a 6.9 crank is actually a 7.3 crank.... Makes sourcing parts so much easier...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
