So you installed it inline between the engine head and the heater core? That should work, less than ideal but it's easier and will get the job done. However, keep in mind that filter is quite heavy, and the IDI engine vibrates quite a but - the way you have the filter hanging way out there puts a lot of bending moment on that plate you have it hanging off, and your sharp corners inside where you made the relief cut for the A/C liquid line are stress concentrators. You may wanna consider trimming the thing down, like chopping the excess length past the filter head, and also removing the four corners with slant cuts (say 45 degrees) and using a dremel bit or even just a round file to smooth out the transition between the relief cuts. The result will both look nice and be less likely to develop cracks. Also I would seriously try moving the filter as close to the alternator as possible, reroute the hoses as needed - for example in our setup the coolant filter head's inboard mounting hole uses the same bolt as the fuel filter head's outboard mounting hole (obviously requires a longer bolt). You probably won't be able to pull that off as your coolant filter head is different from outs but you get the idea, the closer the coolant filter is to the tower it's hanging off the less likely things are to fatigue and the more sturdy everything is.
