i have rebuilt heads Already. At the time, I decided to just have the springs put back in as they were in good shape.
Now that I am about to install a typ4 cam, I need to change those out to the comp 910s before I install them(not sure if I will build a short block or just go with my runner)
It has been said a .030 shim is just right and I want to make sure I get these right. Do the stock retainers work?
Comp sells shim kit. Pn#4754. Spring Shim Kit: 1.437" O.D., .645" I.D.
Is this what I need to order?
Is there a way to make sure I am doing this right, as in what do I need to measure to make sure they are installed to spec? Any advice would be predicated and might be worth a full write up as I install these so other can match it when they install the camshaft.
