cold starting tips
goldsjos18
wisconsin
i know this is probably a repost. but what are some tips when the temps start dropping. ???? new owner of a obs 7.3 and its getting to be below 20 here
Plug it in.
Some like to run 5w-40 synthetic.
I'm running a 15w-40 synthetic.
Make sure the glowplugs are good.
Carry a extra fuel filter, along with some anti-gel or diesel 911, just in case.
greenskeeper
PA
Know the condition of:
1) starter
2) batteries
3) glow plugs
4) glow plug relay
5) fuel additive (anti-gel)
You can wait a little longer after the WTS light goes out as the GPs are still energized. An LED light wired to the load side of the GPR can show you when the GPs are activated.
Block heater helps but is not necessary, I've started both my trucks to -20F without being plugged in. The key is having those 5 things listed in good working order when the cold weather hits.
FORDF250HDXLT
Maine & Oklahoma
about 10 degrees outside.i went out to run to the post office with the civic.started up in about 5-7 seconds of cranking.
took chip truck out to dump a load.started up in about .5 seconds (yes.under a second) of cranking.
so i guess my tip is; turn the key.:D
bbjordan
Snow Monkey
Ashern Manitoba
don't chop my balls off, I didn't make it LOL
In that case, you are forgiven. Just trying to raise the grammar bar on the OB site. :angel::rolleyes:
You must be getting mellow. I fully expected a flipa. LOL
Grammar: The difference between knowing your ****, and knowing you're ****. LOL
To the OP, sorry for the hijack.
LOL
your gat yer workin cut out for you, there sum kinda speccel papole hear!
IDIBronco86
