codes
aaklingler
Winfield, PA
I pulled the following codes off of a 00 f250 with an edge juice with attitude and an aftermarket intake the truck has a lope when up on high idle can you tell me whats going on?
0470 EBP Exhst press sensor ckt malfnct No-start or crank mode Biased sensor, open signal return
0478 EPR Exhst press control valve high input Excessive back pressure - run mode Plugged sensor line, stuck butterfly, restricted exhaust
1209
1211* IPR ICP pressure above/below desired Continuous and KOER on-demand test IPR valve failed, stuck, or shorted to ground
I cleared them and 470 and 478 came back after the truck running for a couple minutes. 1211 came back after the truck being driven 50 miles.
94f450sd
somewhere,ma
the 1211 code could be caused by the programmer calling for more high pressure oil than the system can supply.bad injector orings could cause the 1211 as well.
Cv axle
