Diesel_brad
Dunce
GO SMF.
I did this on both of my powerstrokes and they worked absolutly flawlessly. I cannot comment on which brand to use but i used a SOUTHBEND OFE in my 2000 and while it never slipped it sucked for jockeying a trailer around, it was either IN or OUT. Make sure if you buy a clutch you buy it according to your HP level
With a idi a stock Southbend,Luk,Valeo, Centerforce, Napa will all work just fine. Just make sure it is for a diesel. The gas pressure plated will not put enough clamping force on at the low RPMs these engines need
