Clutch pedal lever assembly
va350
Fredericksburg, VA
Does anyone know where I can get a new clutch pedal lever assembly. I just replaced my clutch master and slave cylinder along with push rod and bushing but there isn't much left of the piece the bushing fits over. I'm afraid it will eventually break off.
If you are talking about the little arm bolted to the cross shaft, it's a replaceable part from Ford, check the stealership!
I'm guessing yours looks like this?
The removal of the old one...USUALLY requires the removal of the pedal assembly....usually, however I have determined that my SLIP on power steering pulley puller could be used for this....You may have to grind one edge down a bit with a small grinder but once it slips over the arm it should be good to pull the arm off....Just sayin...
I'm talking about this style here
I cannot say for sure it would work...but it's the best idea I have for in truck removal!
