Clutch line - is this right?
madpogue
Madison, WI USA
Well, I've pretty much determined that it's internal. TO bearing or the pivot on the fork or something (would this truck have that pivot ball on the fork like the OBS/ZF does?). I had the shifter boot out, and when I operate the pedal, I get a distinct squeak near the bottom of the travel, coming from the bell housing. And as I release the pedal I get the slightest bit of sticking. Not enough to keep it from working, just that it's not silky smooth. I noticed a couple of visual access holes in the bell housing on top, you can see the PP from the cab through those holes. I can't help but wonder if there's a way to get some lube in/on the shaft and/or TO and/or that pivot, reaching in with a tool through those holes. Don't think I want to spray anything in there; I wouldn't want to get it on the clutch faces. Anybody ever tried anything like that?
Oh, that hydraulic line is actually more rigid than it first appeared. So that was a (bad pun) red herring...
RangerDanger
