clutch issues
remington88
Pittsburg, Kansas
ok so i have a 92 f250 5speed. just the other day the clutch pedal wont come up all the way and its hard to put it in gear. i have read the tech artical about using the heim joint instead of the bushings. is there anything else that might not have been covered in there that i need to know? any tips tricks and the like.:dunno i plan on going after this issue this weekend after work sat.
FoMoCo
Olmito/Texas
I have had the problem with hard to get in gear. I had to change the bracket that actuates the clutch. I also changed the Master, line and slave. Which you can get at NAPA as a complete unit. As far as the pedal not coming up all the way, you might have some bad bushings, you can get these at Ford. My other 94 F-350 does have the heim joint system, and it is by far a better feeling system.
JU57US
