otisd85
okay fellas, i did my first clutch in my dads 1975 chevy shortbox 4x4 when i was 14, im 25 now that clutch still works great and i have 4 other chevys i have replaced the auto trans with sm-465's, and helped 2 friends do the same thing. thats 7 total before this truck, all of them have been gas burners, a 454, a 402, and the rest a variety of sbc's.
i seem to be having difficulty with the one between my 6.2 and nv4500, the clutch i use is a MU1909-1C, its just a NAPA clutch. the base number is the MU1909-1, the C at the end is the ceramic version. like i said ive put this in 7 trucks now, and the only problem ive ever had was when i installed the throwout bearing wrong on the fork(my bad), other than that they have all worked flawlessly, until now.
the truck im working on is the one in my sig and my avitar, and is the 8th truck ive put this clutch in but my first 6.2 and my first nv4500. the first clutch i put in this truck gave out after about a year, #2 and 3 lasted about 4 months each. all 3 failures have been due to the springs in the center of the clutch disc breaking apart, falling out and wedging between the disc and flywheel or disk and pressure plate. there is no slippage when this happens its just that the clutch wont dissenguage. i havent tried any other brands of clutch because this has been warrantied but i dont really want to keep doing this over and over so im looking for different options or some thing im overlooking.
i know some of the later 6.5TDs had dual mass flywheels but i dont know what that does for you, or what difference it makes if any, or if it even has any relevance to this at all
i dont know what else to try or where to even start but i want to do something different this time and hopefully remedy the situation.
thank you
thank you
