Trying to get the clutch on my 94 to work. Its got plenty of fluid and Ive blead the crud out of it. What else can I do to get it to fully operate? The pedal goes down and wont come up. Im not sure if its moving enough either.
Im not sure what the deal is. Do they make an adjustable linkage and if so where can I purchase this? The slave cylinder is moving about 1 inch.
There is no need for an adjustable rod, since the system is hydraulic it is totally self adjusting. The rod will only control the relationship between the pedal and the master. It will not increase the movement of the slave cylinder. The pedal doesn't come up, because the spring under the dash doesn't make it do that. It takes presure from the clutch fork to make it come up. If it isn't coming up, then there is still air in the lines. I know how difficult this can be because I am wrestling with this very problem myself. The clutch worked fine until I pulled the fork to service the TOB. The slave did not have a retention strap, and the subsuquent fight to get it all back together allowed plenty of air to get in. Now the behavior is that if I pump the pedal up fully and back down about couple dozen times, it will get to the point where it will come up on it's own. But after some hours, it will fail to do that and it has to be pumped up again. I've never run into that problem. I can see air in the fluid, and it is foaming somewhat. It could be that I need to replace the slave at this point. Pushing the rod in all the way and trying to bleed it like that only seems to make it worse. It IS very frustrating, but these clutches can be real buggers to get bled properly.
the overcenter spring on the clutch pedal locks the pedal to the floor . It's not a return spring , but an overcenter spring, During the top half of travel it returns the pedal to the top, and during the bottom half of travel it assists in bringing the pedal to the floor,
