Got my factory turbo kit installed on truck. Can't get the intake hat to sit on intake manifold right, like I need clock it down. How would I go about doing that?
Yeah I don't know why it wasnt clocked right, was a used kit. thanks typ4 helped a bunch turbos mounted on the truck, dp clamp broke but couldn't resist taking it around the block. I got 6 psi on the drive.
I've had two idi turbos rebuilt, one from Conestoga one from R&D both required clocking. There are a few bolts, no band clamp. Just make sure you have a spare oring incase it tears if it's sat any length of time since rebuild
