Climate controls
Dieselpowerking
Lewiston, idaho
So my climate controls wont switch from defrost and the temp wont switch from heat. Am I looking at replacing the switch? I have vacuum at one of the lines that goes into the cab. 4x4 doesnt work but I have vacuum at the lines when it's in 4x4 and 4x2.
Oledirtypearl86
Whitehall MT
You should have 1 vac Line entering the cab to the selector valve then at the valve it branches off to the areas needing vacume and it should be accessable without removing the dash
ntjapkes
