While replacing my injectors, IP, Lift Pump, Glow Plugs, and Filter housing O-ring today, I noticed that the steel line to the lift pump is severely kinked, in addition to not lining up with any of the plastic tabs which hold it in place on the engine crossmember. Would it be o.k. to replace this steel line with diesel rated fuel hose? Also, how would I go about connecting the fuel hose to the plastic line from the fuel selector switch? (Should I eliminate the plastic line, or is there a fitting on the FSS which requires it?) I thought I'd get some opinions before I rip into it(and potentially break the fss fitting.) Thanks in advance.
Peter Arnsdorff
Peter Arnsdorff
