The "I" terminal brings the alternator system "online" when the keyswitch is turned to run.
The "A" terminal is not the output terminal, this is the feedback sensing wire for the regulator to monitor the system voltage. It's tied to the battery + somewhere convenient so it can sample the voltage.
The "S" terminal goes to the stator in your original trucks configuration(one of two Ford used, you should stick with it). Make sure this terminal is hooked to the stator of the Chrysler alternator, I am not familiar with the Chrysler alternator, but it does not have two fields, it will have one stator terminal(the windings mounted to the outside of the case) and a field terminal.
The "F" terminal hooks to the field terminal of the alternator. The regulator takes the info that it gets from the "A" terminal, and sends a varying voltage out on the "F" terminal to control the charge output of the alternator. More voltage on the "F" means more output. Be careful and do not short out the "F" wire while it's hooked to the regulator, it will burn up the regulator.
The first thing I would try after you verify your connections, is take the "I" wire off the regulator, and run a jumper from it over to the battery + terminal. While it's hooked like this, run the engine and check the voltage(should be around 14v or so). If it starts charging, then your charge light problem from the dash you have been suspecting is the problem, and you are not getting a trigger signal from the light to the "I" terminal. Do not leave the "I" terminal on the battery + all the time, it will keep the system online with the truck off, and run the battery down eventually.
