The FNG
NOT a Powerstroke!
Has anyone had issues with or warn out a pressure driven centrifuge?
I have a 55gph fuge (OC-20) from Dieselcraft. I'm pretty sure it is exactly the same as the PA Biodiesel fuge. I bought it second hand from a veggie guy who I am assuming put some good use on it. He made 2 sight holes in the cover to see what was happening inside, which is actually really nice. Since I bought it, I have run 600+ gallons of WMO through it problem free.
The last batch I made is when I began having issues. Everything starts out fine, the fuge begins to operate at 40 psi and steadily speeds up as the pressure rises to 80 psi. About a minute after the fuge reaches speed, the entire thing floods with oil and the fuge stops spinning.
After calling Dieselcraft, it was determined that there were three things that could cause this:
1) The drain is restricted
2) The jets are flowing too much
3) The brass bushing (in the center of the rotor) is warn an oil is flowing past it
I checked the drain. It's a 1.5" pipe, restriction is non-existent. I also checked the jets. They look the same as they always have. If my oil is abrasive enough to wear the jets, then I'm in trouble... So really, the only option here is that the brass bushing in the center is warn. It makes sense since it rotates on the shaft.
Anyway, a new rotor is almost as much as a new centrifuge. Looks like I'm getting a new centrifuge...unless anyone has any bright ideas.
