84TD
I used to have the death wobble, ordered a front set of centramatics and it took care of it. I used #8 shot before that an it was ok, not as good as the centramatics.
Just a note of caution with the Centrimatics. I own three good ones and a bad one, all with just over 600 yards of mileage on them.
I installed, everything was tight and spun freely, no "apparent" wobble etc.
As I drove out my driveway, made a hard right hand turn..... then smell of oil permeated the air. Somehow my brake calipers made contact in the turn and tore a hole in the casing. Not Centrimatics fault.... but dang if that wasn't a waste of money and time.... shipping and labor took longer than actual ride.
Make sure there is "really good" clearance between the product and everything else!
I'd try the BB's first, see if that helps, less expensive to "find out" if it works. The thing about the Centrimatics is, they are oil filled along with the shot. This slows down the shot so as not to keep spinning or make noise, stabilizes the shot to even out any shimmies.
I had aproblem with one hitting the calipers also. The guys at Centramatics sent me a different size at no charge.---RobJust a note of caution with the Centrimatics. I own three good ones and a bad one, all with just over 600 yards of mileage on them.
As I drove out my driveway, made a hard right hand turn..... then smell of oil permeated the air. Somehow my brake calipers made contact in the turn and tore a hole in the casing. Not Centrimatics fault.... but dang if that wasn't a waste of money and time.... shipping and labor took longer than actual shipping.
