Catalytic converter and MPG's?
brianjbeach85
Virginia Beach/VA/USA
Does the catalytic converter hurt MPG's that much? I am trying to decide between a 5' MBRP Cat back... or 5" turbo back... My biggest concern is come inspection/emission time obviously the cat back is best way to go, but is it worth the $260? or should i spend the extra 200 for TURBO back and get most gains... the turbo back is 5" with a 4" down pipe... Thanks for help here.. trying to buy this system as soon as i can get educated feedback from you pro's out there.
JohnBoyToo
DFW, Tx
from all I've heard the cat is pretty hi flow....
the muffler is the bottle neck in the exhaust...
A turbo back will give u the best flow, but will you be able to tell the difference ???
maybe....
All testing I've seen is a 5" exhaust is over sized unless you are going for HIGH, HIGH hp with new turbo, and high dollars...
a 3.5" downpipe and 4" exhaust is the best of both world's....
m2rtin
