I found on mine that I cracked them all loose, and then tightened them while still cranking and fuel was moving. Then let it rest, and do the next one. After 4 or so were tight, it wanted to start. Once that happened, fuel came fast to the others, then when I snugged the 5 and 6th lines to make fuel, it started, just snugged the other two and it still ******* and moaned a little until the remaining air was gone. I was getting aggravated though as I would crank until fuel showed, stop cranking and tighten the line down only to seemingly trap air in there again. So once you move fuel, keep cranking the engine (having someone help here is a good idea) and tighten that line. Don't take forever getting it tightened, just snug it and stop cranking, let the starter cool, then move on. I'd have the charger on the whole time too!
