ERnurse
Hi, new to the forum and also the Ford diesels. Im trying to swap my '86 6.9 IDI with a '92 7.3 IDI. I read up on the subject before going to get my motor and was comfortable that I could get it done. My only issues are the differences in the wiring harness. Also the newer motor does not have the vacuum lines on the side of the injector pump. Should I pull all the small electrical parts from my 6.9 and install them on the 7.3 and then switch the wiring harness or is there a way to eliminate the 2 extra wires on the 7.3 and wire it directly to the trucks plug? I was under the impression from what I read that this was basically a direct replacement except for the flywheel possibly. I hope I didn't just waste my money. Only reason I didn't replace with another 6.9 was availability locally and I read that it was basically a direct swap. Any help would be greatly appreciated.....Thanks, Andy
