Starting assembly of rebuild 6.9. My cam end play is .010". Spec is .002 to .009 I removed gear, spacer etc and checked thrust flange. It is just below minimum thickness. It seem that this is a wear item. Manual says to replace it. Problem is, I can't find one. It is discontinued at dealers, and so far no aftermarket source has been found. I suppose a machine shop could mill it down to accept a shim. Have any of you gone through this? Thanks in advance,
Tom
Tom
