Camber Adjustment
u2slow
bilge rat
PNW
Can't blame the lift kit outright. One side has ok caster. Something isn't the same (or mirrored) side-for-side.
david85
Campbell River, B.C.
Here’s the kit I used.
https://www.rockymountainsusp.com/l...wd/f250-f350/1980-96/186f2k-sk.html?c=308&i=0
The kit provided little 3/16s spacers that I put underneath the coils, you can see the little gold spacer in the pictures. Could those be removed to help correct the alignment? I just assumed they needed to be installed.
High spring height = Positive Camber \----/
Low spring height = Negative Camber /----\
In theory, removing that washer will reduce your camber but I don't think 3/16" will make a huge difference.
Dummy99
Florida
I had it backwards then haha. Would adding a larger spacer help then or should I just leave it?
u2slow
bilge rat
PNW
More spacer or spring will reduce caster also.
Is your truck setup heavy on the driver side?(battery, driver, fuel tank, etc)
IDIBronco86
