cam position
cpdenton
Truck needs paint.
Conway AR
I would take that thng out. Seems kind of pointless. Just fix any fuel leaks and you won't need a pump to prime the system.
Are you saying it won't run? It takes a lot of cranking to prime the fuel system after you've had it open with a mechanical pump. Go easy on the starter. 10 second bursts max followed by cool down time in between. It's one of the main reasons people switch to electric.
ericwade381
northeast/md/cecil
The metal hose I replaced with a rubber fuel line not sure if it's leaking where it screws in the mech pump I put thread tape on it it was not leaking at all before I took the electric pump off weird
720Diesel
